DELETED_1840
i5
http://forums.overclockers.co.uk/showpost.php?p=29022095&postcount=74
i3
http://forums.overclockers.co.uk/showpost.php?p=29022061&postcount=44
I did some testing on modern games. Even i3 totally fine FPS in Crysis 3 when OC to 4.5ghz. I put together two bundles which may fit your needs. Including how to OC the none K SKU CPU.
http://forums.overclockers.co.uk/showthread.php?t=18709077
Your 380 or 970 Choice GPU is working well with this bundle and I suggest for gaming you go the best GPU you can.
http://forums.overclockers.co.uk/showthread.php?t=18709080
For Skylake u need ddr4, ddr3 waste of time and u lose perf.
Also to make i3 worthwhile u should OC. U can't on that board or infact any non z170. U need the clock gen on z170 to OC blk.
The bundles I linked u to we warranty the OC. Just follow guide to OC the bundle. I sold many of these already and only one issue. Which was just MB needing RMA. In 50+ sold this is very good success rate.
For u I think i3 bundle perfect.
