DELETED_23244
Try just looking for viewing pics. You can also set iphoto to just copy the files so you can maintain your folders in pictures as normal.
Adobe Bridge
Adobe Lightroom
Both are excellent at organising, but alas not free.
Personally I don't use iPhoto.
I use Aperture, just set up the import options correctly and it wont touch your file structure it just adds them to its library, iPhoto also has the option of doing this afaik.
