The only way you will get the full upload speed on BePro is to use Annex-M as that is how it works!
That is also the reason why you lose downstream speed,its a trade off against one or the other.
Do you know if your line is interleaved at all (Be call it fastpath) if it is currently not then you might give them a call and ask them to turn it on, would raise latency in gaming by a little bit but will increase stability.
eventually there was an accident and a large hammer landed on the master socket so I replaced it myself.
Works fine now.
