DELETED_250231
High gaming performance isn't really opposite to image quality, because significant overshoot is about as much problem for motion as slow response time.
So don't worry about monitor being aimed for gaming.
Again VA's high contrast/better black comes with its own cost for image quality:
Horizontal gamma shift known as black crush.
Basically from straight angle dark shades darken toward black "crushing" darkest shades into black, with shades reappearing when viewed from angle.
For example dark forum theme of this forum would likely show it.
I once had VA panel and that gamma shift was easily detectable from dark web site backgrounds.
This is how it works:
Also dark games suffer detail loss from that even though you might not always notice it when focused to moving picture:
So VA gives with one hand and takes away with the other...
Also 99% of VAs have very slow dark shade starting transitions compared to IPS.
Actually bright text on dark background would show it the worst with major motion blurring:
In image quality LCDs are just broken tech by design and it's question of choosing your poison.
(to think that SEDs combining CRT's image quality to flat size and pixel accuracy of LCDs were demoed 15 years ago...)
Though if you prefer darkened room, then limited contrast/black level of IPS won't cut it.
But if you have some room illumination, contrast difference isn't such visible:
(still wouldn't accept low contrast of LG's Nano-IPS)
So would consider room light level as deciding factor for which LCD types problems are smaller.
I almost pulled the trigger on a Dell S2721DGF a few days ago, but I am glad I didn't now due to the Nano-IPS panel, and lack of an sRGB mode.
While it should be using very similar panel to LG's own 27GL850/GP850 there's been variations in contrast results.
850:1 is apparently achievable for it, while LG's own models have measured even down to 750:1 at lowest.
(curiously 4K Nano-IPS in 27GN950/GP950 measures normal for IPS 1050:1)
AU Optronics would have clearly better contrast IPS panels in general and MSI G273QF has been measured to achieve very high for IPS 1250:1.
Also response times are at top level with LG's panel and it's very well priced.
Though stand has barely any adjustments with only tilt.
MSI OPTIX 27" G273QF 2560x1440 IPS 165Hz 1ms FreeSync/G-Sync Widescreen LED Backlit Gaming Monitor= £258.95
That would be my choise for IPS in that size/resolution.
Its contrast should be fine when room is semi illuminated for as long as you keep brightness at proper level.
Counter-intuitively it's brightness setting which determines how good black can be.
But completely dark room would be certainly problem, unless minimum brightness is low.
Then again even VAs are far behind CRTs/self emissive pixel displays.
It lacks sRGB mode, but there's overall little need for that.
All image processing software worth of mentioning should support colour management.
Also for example Firefox supports it.
https://cameratico.com/color-management/firefox/
I've just got the LG GL850 and have to say I'm delighted with it. Massive step up from the 1080p screen I was using before. It was a toss up between that and the MSI.
How have you been finding the 27GL850-B after a couple of months ? I was looking at the MSI for my son but if you look above then check the price its now nearly £100 more and I didnt really want to spend over £300.
Ended up picking a 27GL850-B from the auction site locally 2nd hand for £200. Collecting it later.
Still enjoying it and haven't come across any niggles or issues. Best monitor I've bought for a long time.
