Grab one with at least an 8X multi if you want an easy life!Kermit said:3) OC wise (yes I like to dabble) do all the [Core 2 Duos] have more or less the same OC potential making the 1.83Ghz version a better buy than the 2.1 or 2.4?
Intel®Kermit said:which Duo's have x8 multi's
Lol u picked the two chips with a x7 multipaul_64l said:e6320
e6300
There's a much bigger difference than that between the 8800GTS and the 8500GT! The 8500GT will still be better than the 6600GT, but not a whole lot I'd imagine. The 8800GTS is pretty close to top end really.paul_64l said:i choose the ballistix ram as it will run faster than the ram u had specced.. even up 2 8500 speeds (1066) with timings of 4,4,4,12 so will make any overclock easier
as far as gpu goes id say that your card is 10% slower thats all.. if your card did 90fps that would do 100 maybe not a lot in it (the 8500 that is)
St0rmer66 said:There's a much bigger difference than that between the 8800GTS and the 8500GT! The 8500GT will still be better than the 6600GT, but not a whole lot I'd imagine. The 8800GTS is pretty close to top end really.
I see, in that case I would agree.paul_64l said:i was talking about 10% between the 6600gt and the 8500gt
