DELETED_3139
Somebody's already managed a proof of concept using an ionising tower.
Plug "ionic PC cooling" into Google and have a look...
This is a similar principe but on a different scale altogether.
Alex UK said:
So is it likely this will be incorporated into future CPU/GPU coolers? Is it a costly technology?
The ion cooled PC was expensive if I remember correctly. But then things get cheaper - look at flash memory.
It looks intersting and I'm sure if the cost can be brought down to a reasonable level we'll see it around in 5-10 years.
The principal could also be used on WC radiators ... after all the principal is the same as air cooling ie move air past fins to cool it.
