DELETED_3139
I'm having the exact same dilemma, due to this I'm probably going to have to shop elsewhere for the shuttle I'm going to build, I don't want to pay 2 sets of delivery costs.
The other alternative that I know will fit from the SFF gallery is the Coolermaster GeminII, but sadly, OCUK don't stock that either.
You could phone/e-mail them and see if they have any plans to stock them, it does seem like a bit of an oversight.
The Thermalright Si128 may fit, and the Zalman CNPS 7 and 8 series should also fit.
The biggest you can fit in is a Coolermaster Gemini II, but I don't think they're available at OcUK.
not gonna be able to fit an si-128 in there as its 91.5mm high i had this same issue when i was looking for a cooler, CM GeminII is about the best your going to get in there or maybe the zalman cnps8000.
Kermit don't most 90mm - 120mm psu fans push air down not up?
my psu fan pushes out
i have seen a thread on these forums somewere were the op has used a coolermaster gemini and used the psu as a fan on top so its effectively not passive. Looked very nice to
I have an SG01 evolution with an NT06 Lite. the PSU im using is an Enermax liberty 620, which has a big fan directly above the cooler.
My CPU is a C2D E6750 that im running o/c'd at 3.4Ghz. i tested it running orthos for 8 hours, and the temp got upto 68degrees max. the temp were tested with core temp :-)
