In essence, with a helicoil you drill out the hole to oversize (a 6.3mm drill bit was supplied), then retap this with a tap (I guess 6.3mm again), then screw in the helicoil which fit the newly tapped 6.3mm perfectly but its inside diameter is M6 like the original thread was
