DELETED_3139
Check this under gpedit.msc
Computer Configuration\Administrative Templates\Windows Components\Windows Update\No auto-restart for scheduled Automatic Update installation
It might be set
edit: actually I'm not convinced that's the correct entry, it should still prompt you to reboot if required like the other servers. This one is only for auto reboot /fail.
Check to see if the following reg key exists :-
HKLM\Software\Microsoft\Windows\CurrentVersion\WindowsUpdate\Auto Update\RebootRequired
Although like Halfmad's point, this is under Auto Update so might not apply.
