Depends
My personal way of doing things is to alternate between original and what I consider to be high quality replacement carts (Viking Direct, I think I'm allowed to post this?). My printer is a HP, & I've found that only using replacement carts will bung up the print head, which then needs to be cleaned using the utility. Alternating keeps the quality good.
Think its something to do with the particle size in the ink- Remember; You get what you pay for
