DELETED_5350
When I first got my Diamondback and adjusted to 1600DPi it felt weird for a day or two but now when I use old standard mouses It feels really bad.
So all in all... get one :D
Yeh i have an old Viper mouse, its pretty decent still, and is just amazing when combined with an eXactmat. It really does help the way the mouse reacts and feels. Get the mat if your getting the mouse
I've got a diamondback plasma, took a while to get used to but it's fine for general use. The side buttons aren't as good as the MX51x mice though. Good mouse overall but I'll probably go back to Logitech when they replace the G5.
Got the Razer Copperhead amazing mouse takes abit to get used to how light it is etc, But once you have you won't regreat it.
if youre not used to logitech then definatly go for Razer.
got my Copperhead and it is fatastic :cool: eve without an eXactmat.. but i think i will be investing in the near future to get the most out of it.
i like my Razer Copperhead, it is very smooth on my BFG Ratpadz GS mouse pad (which is solid hard plastic btw). 2000 dpi setting seems a bit insane to me, ive stuck with 800dpi at 500hz and turned off windows "enhanced pointer precision" overall its just a little bit faster than my standard 300dpi optical but its a lot more precise and smooth :) I also disabled the right side buttons because apart from being quite difficult to press they by default change the DPI setting which i didnt want to do while I'm in the middle of the game. Also once you have it set up how you like, you can save it to onboard mouse memory and you dont need to load drivers from then on.
Id say get one, its pretty much the standard shape for a mouse unlike the logitecs which look like they could take some getting used to.
I got the Razer Pro v1.6. Does anyone know how to stop it from skipping pixels? It skips about 2-3 pixels when doing small movements. That's not good enough for c.a.d like it says on the description. I got the latest drivers. I don't know what to do? Not very good for sniping either.
BarryFell said:
I hated it and sent it back. It felt horrible in my hand and the side buttons didn't work in some games properly so I went back to Logitech.
I tried getting used to the Copperhead for 2 months, but it ended up giving me hand cramps if used for a long session. Its just too small I think for people with big hands like myself. Now using a MX518 and its a better mouse, cheaper.
try to set windows pointer speed in the razer config to 5. helped for me. have a copperhead though.
I have been changing a few of the settings today and i ended up putting it back to default. For some reason it keeps changing it from what i set it to, i set it to 5 and it changes to 5 1/2 or 6. :S
Edit: Aha i know why its set to the same as the control panel, i put it to 10 and it was jumping like mad heh... i had it set to 6 all along. smhemhsmhemhmshmehmhmheheh
I really dont understand the ppl who complain that the mouse didnt fell right, got a diamondbac about 9 months ago and had no problems getting used to it, i have big hands, had a few problems with bluescreens but using the 5.09 drivers none now. Have all the side buttons marcoed up for change views will flying in bf2
it was the same for me when i got mine there a great mouse :)
