You DONT need the bottom chamber fan... Makes life a whole lot easier.
Remove all the plastic bits from between psu chamber and the mobo chamber, route wires nicely then block off the sections you are not using.
I am a silence freak... TONS of dynamat in use on the inside of mine (all internal panels have at least one layer of dynamat, makes a huge difference to the volume). one nexus fan (as I bought one to test how quiet they are... Quieter than the ambers so the ambers will all be replaced sooner or later with nexus's).
Not the neatest, but good enough for me... Can easily work on it by cutting a tiewrap or two... Then just put them back when done.
1 DVD-RW, 1 floppy, 3 hard disks... Using zalman silent heatpipe things for 2 of the HDD's, up in the 5.25 bays.. and one is below the floppy. Got another HDD to go in tomorrow too (top 5.25 bay)... Bottom HDD tray is totally empty (its a pig to work in/around).
PSU is a HIPER type-R blue modular.
*edit - You may also notice that I taped the metal loops used for pulling the HDD trays out down... One was slightly loose, and I knew it would rattle if I didnt tape it down... So taped it before closing the pc up.
**second edit - You may also also notice
p) that I had to cut and extend the 4 pin power connector (top left in the picture)... It pays to learn how to use a soldering iron
You might also notice the castors I fitted... offcut from a shelf (was doing some diy and this bit was exactly the right size), screw castors to it... Much easier!
Cya,
SAm C
