DELETED_5350
Also try disconnecting any mapped networked drives and any network connections to other comps. generally.
He told you - a longboat - he's obviously a viking :D
Back on topic, disconnect all your usb devices and then do several restarts plugging them in individually each time to see if you can identify the specific device which is causing the problem - it's probably on its way out...
well its a good idea to do it so u actually find out whats causing it then you can try n fix it
