8 May 2007 at 21:22 #2 Defcon5 Defcon5 Soldato Joined 4 Sep 2005 Posts 6,424 Location Whitwood, West Yorks Normally in 1 + 3, but check your manual
8 May 2007 at 21:22 #3 Will_3rd Will_3rd Soldato Joined 13 Dec 2005 Posts 6,418 Location Reading, Berkshire depends on the how the motherboard works, check the instructions to be sure
8 May 2007 at 21:22 #4 Bailey_sufc Bailey_sufc Associate Joined 27 Aug 2006 Posts 260 smoove said: Do ram sticks have to be inserted next to each other on the motherboard or can they be 1 in each side? (I have 2 banks of 2) if you get me. Thanks Click to expand... if i get what you mean then yes you can
8 May 2007 at 21:29 #5 Bailey_sufc Bailey_sufc Associate Joined 27 Aug 2006 Posts 260 what is the mobo btw?
8 May 2007 at 21:34 #6 PhillyDee PhillyDee Soldato Joined 12 Feb 2007 Posts 14,116 Location South Shields Match the colours also works. If it works in dual channel, it will tell you at the POST screen. i.e. Mine is Slots 1 + 3 (Yellow and Yellow).
