I take it the 4800 x2 would be s939 with you having ddr1. The s939 versions are VERY expensive and not worth it at all. I Would just buy all new, something like an e2180 and p35 motherboard. If you really want an s393 dual core then make do with the 3800 x2 and overclock it
Also. the 4gb Ram upgrade is going to be pretty pointless. Hardly anything can use 4gb at the minute. And i wouldnt be investing in the old AMD Tech either.
As above, start from scratch and get yourself a Wolfdate setup.
