DELETED_5350
Does it work without opening the port? If no, open the port and see.
And yes starting and ending at 9090 will only open 9090
Right, not sure what here is wrong, but i'm using online port checkers and it stating that my ports are still blocked. (Software firewall/Windows firewall is off).
This is a typical scanner response when a port is open but there is no service listening behind it.
smoove said:
Invalid vBB code with two URLs stuck together but I see you've rehosted them at imgur as requested by fluff.
I've set my Pc to static 192.168.0.2, and put the DNS server as 192.168.0.1 (which I assume is what you do for it to get Dyndns servers) and setup an account with Dyns and entered my login details for the service in my router.
What am i missing?
- Change Config -> General -> SABnzbd Host from localhost to 0.0.0.0
- Save Changes. Restart SABnzbd+
- Approve Windows firewall popup for sabnzbd.exe on your private network.
- Enjoy.
Further reading: http://wiki.sabnzbd.org/
