DELETED_5350
1) 1 fan either 120/140mm, comes with a 140mm Blue LED fan fitted.
2) 1X 120mm
3) 2X 120/140mm
4) yes.
I am 99.9% confident the above is correct.
Not a fan of the GFX card bracket. I would just stick a fan on the side. You can fit a 80/120/120mm fan on it.
Anyone have any recommended air flow diagrams, or something of the kind, for this case? For example, which ones to have as exhaust and which ones for inlet?
1 x 140mm front inlet.
1 x 140mm bottom inlet.
1x 120mm rear exhaust.
2 x 140mm top exhaust.
Never had a case that allowed a side fan, but would imagine this would disrupt the airflow.
yer was thinking air in through the front and bottom and out at the top (heat rising and all that crap)... Funny you should say that about the side ones, i put a CM Sickleflow 120mm fan on the lower side spot as an inlet and the noise was horrendous, dont know if its through vibration on the side or the way that the case is designed for the air flow
