DELETED_5350
Xpenology is not ready for DSM 6.0, do not update otherwise you'll have a hell of a time dropping it back down to get it working again at a 5.2 level; just update to the latest security patches and leave it there until the devs say they've cracked it.
The consequence of updating is generally loss of volumes, inability to create new ones etc.
Be aware that DSM 5.2-5967 breaks the power settings
All works except power settings
I would stick with 5644 for now(wish i had now)
Ah yes, I don't use the power settings as I keep my box running 24/7, but if that is a concern for you then use the previous image.
