It's not loading one or more CSS files for styling. This is why it's defaulting to the default font (typically Times New Roman), no colouring, and everything is aligned to the left.
I'd also check the hosts file for any weird entry and make sure that you're not using a proxy (check internet settings -> Connections -> Lan Settings).
Hmm, do you have another device you can test with on the same internet connection? What ISP are you with? Could give this a go to see if you get any packet loss that could cause a problem: http://www.pingtest.net/
Hmm, well seeing as it's the laptop, I assume you connect it to the router via wireless? Could give a wired connection a go to rule out it's not a shoddy wireless adapter in the laptop?
