deleting shared memory c++
23 May 2005
Auckland, New Zealand
Hi, i've drawna bit of a blank on this one..
say i have an object class like this:
Code:
class Object{
public:
   ~Object();
   void SetMaterial(Material *m)
protected:
   Material* materialPtr;
Object::~Object(){
   if(materialPtr){
      delete materialPtr;
      materialPtr = NULL;
void Object::SetMaterial(Material *m){
   materialPtr = m;
And I declare two objects with the same material like so:
Code:
Material* Material = new Material();
Object* Object1 = new Object();
Object* Object2 = new Object();
Object1->SetMaterial(Material);
Object2->SetMaterial(Material);
When the objects get destroyed, each object tries to call the material destructor.. breaking the program. How would i fix this? Any help appreciated :)
Joe
You can let the creator of the material destroy it (so Object doesnt delete it), or you can ref count the material (i.e. each object calls Inc/DecRef), or you can use a smart pointer to ref count (the last two are similar but subtly different).
