Ok, very soon im gonna delid my 3570k,seen some vids on you tube and its well within my capabilitys
so my cpu needs more volts but runs cool at the moment,(currently running 4.3ghz @1.3v with a hyper 212+ and hits about 71*c max with prime 95 running for an hour)so I have the headroom!!
But if I oc to 4.5ghz+ things start getting warmish,(up to high 80s and above)
I want to oc as high as poss,so a delid would hopefully keep my temps down.
Is it ok to run vcore at 1.5v+ (for benching) im a bit worried about using that much voltage.
PS cant afford better cooling at present.
