Deliding 3570k
Man of Honour
17 Feb 2003
Chelmsford
I'm ready to delid tonight this but just have a few questions.
Do i need to reattach the lid with thermal adhesive or can I leave loose.
If I do any recommendations? I'll have to buy some if i do.
MX4 or AS5 ok for the die?
edit - MX 4 is a discontinued product :p
Use Mx5 not as5 is it contains silver which is conductive
Once delidded put paste ontop of the die,place on the metal cap you've cut off and clamp it down into the mb with the CPU retention clamp,then apply thermal paste ontop and place CPU heatsink/cooler
You'll get better results if you carefully scrape off all the black adhesive thats used to glue the CPU cap on
I have the bit-tech guide to hand :)
Do i need to adhere the IHS or leave it tot he retainer to hold in place?
All I can say is good luck Mr Huddy :)
Stelly
I'm feeling adventurous.. but now you un-nerved me :p
Just use the retainer,no need to re glue it,place on loose and the clamp will hold it in place,just hold it in place as you clamp it down and use non conductive thermal paste
why should as5 matter being conductive, most like myself use liquid metal??? which also gives the best results.
http://www.overclockers.co.uk/showproduct.php?prodid=TH-005-CL&groupid=701&catid=27
when i put my chip back in with the loose IHS i lay my PC on its side, in otherwords get the mobo flat, then place a finger on the IHS whilst clamping it down to steady it as it can slip about.
Let us know how you got on, as far as i know, you are perfectly able to run with a delidded CPU without having to reattach the IHS can anyone confirm this?
It can be done. Its not for the feint hearted though, too much clamping pressure from the cooler and you have a crushed cpu die and you're shelling out for a new cpu.
I'd delid mine but theres a chance mine may not use TIM so attempting could leave me with an expensive keyring
Use Liquid Metal or dont bother doing it.
The big temp drops come when you have correctly applied LM and carefully placed the lid back on and clamped down.
NO NEED FOR GLUE, it would be a PITA anyway if you wanted to reapply TIM.
Ordinary paste will work short term only.
It will quickly be forced out from between the core and IHS.
Some sort of capillary action due to pressure and heat.
LM is the most effective in terms of temp drops and is permanent.
Use MX4 or similar and you will be constantly re applying it.
Top of the IHS isn't important any decent paste will do.
Warning LM is very slippery the lid will slide about like an ice dancer on greased skates till you clamp down.
Keep the IHS square in the socket and let the clamps fix it firmly in place.
Running bare die is risky unless you use one of the bare die kits.
I have done it but heatsink clamping pressure is critical and often some of the pads dont make proper contact resulting in no post.
true im using liquid pro myself,just take care not to get anywhere else other than on the die
and pcz is right I saw no improvement with mx4 only with liquid metal but it depends on how badly the paste was applied at intel
but for arguments sake out of mx5 and as5 id pick the non conductive paste
I'm another that would recommend liquid metal for this.
I hate the stuff but the one place it's really good is between a de-lidded IHS and the silicon.
This also echoes my experience, when I did it the first time on my 3770k I saw "okish" results, with AS5, did it a second time with MX4 - no difference, switched to liquid metal and I lost 15 degrees, full load temps @ 5Ghz on water are now no more than 75c, (they were over 100c @ 4.5Ghz before I delidded)
I'm going for the mx-4 but leaving the lid loose.
Liquid metal is the way to go mate, it's the nearest equivalent to the solder that is used on the sandybridge CPU's, this is why they run cooler than ivybridge. Replacing thermal paste with more thermal paste is not going to give much better results IMO.
