Ive posted a webnote but realy need a quick-ish answer. How long have i got from recieving an order to sending it back if it is incorrect or damaged.
The reason i ask is im after a couple of bits from the 'This week only' but am out of the country til the 4th Dec. I doubt i'l be able to check the order is correct and servicable until 5-6th Dec. Would i still be able to return any items damaged or incorrect.
Thanks
Thanks
