Can also get LCD screen wipes which will dry without leaving smears, but if it's just dust then use a duster. Whatever you use try to keep the pressure to a minimum, and don't use anything that's likely to scratch it.
Cheer's Ill go with the wipe's hate having smear mark's.
So much better having the resolution at 1680-1050 rather than 800-600 which I had before ,dont have to keep scrolling now. Another thing when I connected the dvi cable it said no vga cable and when blank so I had to go back to vga?
