Dell 2007WFP - match up
8 Nov 2004
Hi All
I have the above monitor and want to have a dual monitor set up for work. I want to match the screen up with another 2007WFP but can find any for sale on ebay. Whats the closest Dell model to that which will give me similar image quality and the stand that will let me rotate the screen 90 degrees. I saw Dell sell the 2009W but noteiced that it was a TN panel and not very good. Your help is much appreciated.
Thank you.
The 2007WFP was the last of the quality Dell 20" screens. The next best thing is the 2209WA which has a decent panel and stand but is larger than the 2007WFP so won't fit perfectly next to it. They have the same resolution though, if that makes a difference.
Only other thing would be to get the 2009WFP and use that as the secondary monitor and the 2007WFP for more important stuff.
Thanks. Thinking about it more I am not sure if I can deal with 2 different sizes or screen quality. I may just sell mine for about £200 and spend £300-400 on 2 of the same new screens. Is there anything I can get for that price rance that will rotate 90 degress and is on par with the 2007WFP?
