- 6 Sep 2005
Hi guys
Just wondering if anyone else has had this problem...
I bought a 2405 from OCUK about 4 months ago and all has been fine up until about 10 minutes ago.
I was using media player and the image was a little dark so I turned the brightness up from 0 to 50, no problems there.
When I came to turn it back down again nothing appeared...
After 13 seconds so the brightness/contrast menu appeared slowly but it's corrupted, the colours are there, but there is black lines scrunching up and overwriting the writing and brightness bar.
If I bring up the main menu I get the same problem.
The monitor has been on since 10AM but I can't see that this would cause a problem.
Has anyone else experienced anything like that?
*edit* I should note that the display itself is fine, colours are good, things move as it should...it's just when the menu is brought up...very odd!
