Dell 2405fpw: any way to disable auto-adjust?
21 Oct 2002
Maidenhead
Absolutely fantastic monitor, but I'm having a minor problem. I'm connected through vga, and I get a great image once it's set up right (imho as good as DVI). However, every time I boot up my PC, the screen automatically auto-adjusts and ends up really blurry. I then have to do a manual auto-adjust (from the OSD) to get it crisp and clear again. Is there any way to disable the automatic auto-adjust that the monitor does each time it's switched on?
Ginga
why not get a DVI cable / use it? When i had mine running on VGA i dont think it auto adjusted every time i booted up. Have you made sure you're set at 1920 x 1200 and at 60Hz?
Cheers for your response mate. I must admit I'm fast coming to the conclusion that I should just use DVI. I actually run two PCs through the monitor - my games (sig below) and work PC. I was running the games PC thorugh the DVI because I just assumed that response time would be better. However, seeing as I spend more time working, I should prolly use the best connector for the work PC. The shame of it is that the VGA image quality is top notch - easily as good as DVI. If only I could disable the auto-adjust I could have the best of both worlds.
Ginga
the DVI makes no difference to response time at all, only to image clairty. There's a slight noticable difference in image quality i find between VGA and DVI myself
Thanks you sir! There prolly is a slight improvement with DVI, but I'm still impressed with the quality of the image through the VGA - was expecting much worse.
Ginga
