dell 2405fpw contents
7 Jan 2005
Nottingham
was it just mine or did any one else not get a power cable with there dell monitor. I sent a webnote and they said i was going to get one forward to me. Not recived it yet any one else
When I got my FPW2005 (this is for all three), I had the following contents:
DVI cable
Analogue cable
Monitor
Stand
USB uplink cable
Power cable
Driver disk
You should have received the same as posted above.
it is shipped in a seperate box, so sometimes it is missing with the 2405FPW. Contact the shop by phone if you can and i'm sure they will send you one out
OK cheers baddass
Yeah when my friend got a 2001fp from OCUK he didn't get a power cable. Luckily I had a spare one (as its a funny one) he could use.
When I got a screen direct from Dell (which proves the point) it came in 3 boxes :)
1 = Screen
1 = Power Cable
1 = Manual.
Seems a very silly way to do things!
not really, you make the monitors all the same and then depending on country it is shipped to, you add the coresponding power lead and manual, saves on having stock designated for one country only filling half your warehouse.
