Dell 2407 flicker normal?
10 Apr 2006
Edinburgh
This is poss a silly question but i notice a flicker like when i do a search on google (the top blue bar for example when you have search results),when i move the page up and down its quite obvious.You can see obvious `white` bar underneath/above it when moving.
Seems to be quite obvious on white pages,with blur on dragging results quickly
Is this normal then? (i`m not sure i`ve moved from crt)
cheers
Aye it was on desktop,it goes away if i go into any of other 2 modes hmm,i`m guessing desktop is `lazy` mode.
Try http://www.xbox-scene.com/ tho,and drag the up/down bar on right of browser and theres real flickery lines throughout the grey.
Just trying to figure out if this is normal or duff
Cheers
