Hey,
Just wanting some help as I'm tempted to finally buy a high quality Dell monitor I'm just confused about everything that has been said about these monitors -with all these model numbers and different versions flying around on the net I'm finding it hard to establish which is the best.
I've come to the conclusion that the 2407 WFP A04 Rev is the best one you can get at the moment, apparently fixing banding issues and there is no ghosting? (that correct?).
I've also read that the HC version is the one to get as its got "higher colour" on the screen itself - however after some reading it seems that the HC version only goes up to Rev A02...
So i'm slightly confused as to whether the HC is better or the A04 - The net brings up the HC version has ghosting issues where the A04 does not, but then the HC has better colour than the A04?
Lol i'm in a mess and would really appriciate it if one of you guys could help me out.
My current monitor is a Samsung 226BW, and i'm wondering if the colour difference on the screen will be that noticeable? Hoping for a wow factor to be honest.
Thank you
Thank you
. omaragha do you have any real-life images?
