dell 2407wfp questions
15 Oct 2005
the optimum resolution is 1920x1200 but in some games when i set the resolution to lets say 1600x1200 i see black borders around the screen
is it possible to remove those? is it because of the game or settings on the screen itself?
You're currently running the screen in 1:1 mode, you need to change it to fill mode.
It's an option in the "Display Settings" submenu on the monitor :)
:edit: The image will be stretched sideways though, not sure if that bothers you.
It might be something to do with your drivers, try looking through your settings for something about scaling and set it to use your monitors built in scaling.
sorry to jump in but its greyed out in my settings aswell so went into the nvidia control panel and its ticked to let the screen do the scaling so it should work shouldnt it,p.s could load the drivers from the cd as im on vista 64bit and there is no drivers for them,any help please
i dont think the drivers made any difference to me mate :/
i am using the drivers that were needed for the bioshock demo (beta)
