It will support 1080p 1:1 mapping on VGA DVI and HDMI.
I've had one (now got two 2408s and they're the same).
Thanks for the reply...do you happen to know if it does 1080p 1:1 mapping over Component, and if not what does it do?![]()
I don't know for sure, but I'd say it can as component is the same as VGA.
Mine doesn't support 1080p over component, just 1080i. I think you need to go to engineers menu to enable it the 1080i.Its a while since i messed with it.
