Dell 2407WFP Scaling Questions
16 May 2005
Cold waters
Hey
Apologies for yet another 2407 thread. I've read a lot on here, TFTCentral and other sites, but there are still some things I'm not certain about. Bad scaling is my biggest issue with monitors so I just want to be sure about some points.
2. If you feed 1920x1080 (AKA 1080p) over VGA/DVI and have "Wide Mode" set to 1:1, will they both display with appropriate small 60 pixel borders at the top and bottom since the screen is 1920x1200. (importantly, if a PC is used to test, no "center output" should be set in the nvidia drivers - no help from the device that's ouputting! :))
Thanks. I'd really appreciate it if any owners could take the time to set it straight. :)
The component on mine is awful with my xbox 360, really looks like its around 480p input quality. I have an A02 revision and it seems nothing has been done to try and sort the problem. Only solution for me is to get the VGA connection for it I think.
Probably best. I think VGA is always the way to go for 360. It looks perfect on my CRT.
Can anyone help me out? Could a 2407 owner please try out number 2, it's the most important to me. :(
