Dell 30 inch,what card
2 Jan 2004
Kent
Hi All,
I friend of mine wants to buy the Dell 30in flat screen,he's motherboard only has a agp slot, are they any AGP cards that will run it ok.
thanks
whats the model number? If its the 3007WFP, then I dont think it supports AGP cards at all according to the OCUK site.
- Before purchasing this product make sure you have a compatible graphics card that supports Dual Link DVI / DVI-D such cards are the ATI X1300/X1600/X1800/X1900 series and NVIDIA 7800 series graphics cards.
- This product is not compatible with AGP cards
http://www.overclockers.co.uk/showproduct.php?prodid=MO-008-DE
i think he has a r600 ati card, runs his dell 24in ok, he is not into gameing. just dvd's music and surfing
Any card with dual-link DVI will do. If he can afford the 3007WFP he should also be able to afford getting off AGP. The 7800GS+ will do, but my performance increased about 25% moving from a £270 Gainward 7800GS+ (AGP) to the similar £200 Galaxy 7950GT on PCI-e.
So he only has agp and yet he has whats rumored to be the fastest, biggest, hottest gpu for pci-e that require a new standard for power?
Not to mention hasnt been released to anyone bar game developers.
I think not :D
Lay z boy-Very helpfull-feel free not to give me advise in future.
Jpmonkey69-Many thanks for you info, i did read that on the O/C site.
There are quite a few around after a quick look on google. How much does he want to spend? The Leadtek 7600 GT on OcUk has dual link http://www.overclockers.co.uk/showproduct.php?prodid=GX-088-LT
Something a bit cheaper the Sapphire X1300 also has a dual link: http://www.sapphiretech.com/uk/products/products_overview.php?gpid=124&grp=2 Not 100% sure that the one on OcUk has from the description, you'd need them to confirm it.
You get a 1280x1040 res on the 3700 I think if the card doesn't support it...
