Dell 3007 questions
2 Jan 2004
Kent
Is the sound bar for the 3007 worth getting, i use headphones at moment due to late night playing.What is cost of it.
The cost is for you to find (don't think there're many places you can get them from, but one goes without saying). The quality is ok. It's a convenient solution with passable sound, but don't expect miracles from it.
3007 advise please
Can no longer see whole of desktop, was able to when i originaly instal'd drivers but now bottom inch of pic is missing,should show some writing.
Are you just saying part of your wallpaper is missing? Set it to stretch if that's the case.
these can be had for free when buying from some suppliers.. but i think there around £15 or something like that.. the quality isnt amazing.. but its better than i thought it would be.. like said.. its a convenient solution
Thanks for the info, Will have a look at getting some, just wanted to see if any one said they were crap..
Thanks Again
Desktop background is set to stretch,You can just see the tips of the writing below "one shot ahead of the competition"
