Dell 3008 Wall mounts
20 Oct 2004
Nottingham
Fine people of monitor forum.
I want to buy a wall mount for my Dell 3008. It has a VESA 100 mount which is recessed into the monitor casing. Most if not all of the wall mounts I can find that will take a 30” screen have a mount that is VESA 100 and 200 compatible which means the face plate is 200mm and wont fit into the recess.
Do you have any idea if these will still work ?
