Dell 4K UHD USB-C Monitor - S2722QC with Refract Azure PC
23 Jan 2024
Lincoln
Hi, I have just bought the Refract Azure and Dell S2722QC 4K monitor. The monitor came with a usb-c cable to plug straight into pc. However the Azure needs the monitor plugged into graphics card which only has HDMI ports. The usb-c port is located on top of the tower. I’m a newbie at all this! Please can you advise the best way to connect - use usb-c with an adapter to hdmi or just use an HDMI cable and not bother with the usb-c cable. Thank you!
