Dell and warranty issues?
11 May 2007
Just wondering, if I picked up a Dell lappy, with 1GB of ram, and then chucked in 4GB - would this void the warranty?
I'm not sure what sort of 'warranty seals' they have on the chassis - but if none are broken, and I switch the original 1GB back should a problem arise... would they notice?
I don't know about dell's warranty, so I can't say with any certainly, but with most laptops I've had user installed upgrades don't void the warranty, as long as the parts in question are a compatible spec and do not cause damage to the system. If the system is damaged and the problem is linked to the new parts, then it is normally voided. Also, the new parts are obliviously not covered under the original manufacturer's warranty, only the original laptop parts.
Again, don't take my word, look it up yourself!
Is the processor and OS 64-bit? If no, you're only going to be able to use 3GB of that...
didnt realise ram was limited by the cpu. thought it was just the os that limited the use of over 3 gb of ram.
StevenG
long time no seee sr4470
One sexy laptop. Finally decided on one!
Looks like I wont need to upgrade my memory.
Cheers Rich/Pulse, he found a bargain for me earlier...
Dell XPS 1530
Intel® Core™ 2 Duo Processor T8100 (2.10 GHz, 800 MHz FSB, 3 MB L2 cache)
Vista Ultimate
4096MB 667MHz Dual Channel DDR2 SDRAM [2x2048]
NVIDIA® GeForce™ Go 8600M GT with 256MB dedicated graphic memory~
15.4" Widescreen WXGA+ (1440x900) TFT Display with TrueLife™
320GB (5.400rpm) SATA Hard Drive
1Yr XPS Premium Warranty Support - Priority Call In and Onsite Support
Bluetooth
Upgraded battery - Primary 9-cell Lithium-Ion Battery (85 WHr)
2.0 mega pixel Camera & Tuxedo Black for CCFL Display
£769 including delivery.
Not sure, I've had a look at the vostro's a lot lately.
I just checked the Outlet site and found this..
XPS M1530 CORE 2 DUO T9300 2.50GHz
Memory Dual Channel 4.0GB (2x2048) 667 MHz DDR2 SDRAM
320GB HD SATA (5400rpm)
ASSY, BASE 256MB NVIDIA GeForce Go 8600M GT
15.4 WXGA (1280x800) with Truelife
English - Vista Home Premium
It's a 9 cell, how far do they stick out?
It's £690 excluding delivery.
Not sure if they even stick out. Which laptop option is that? Adding the T9300 usually costs a fortune...
