Dell Axim X51 and CF GPS Recievers
1 Dec 2004
S.Wales
Has anybody had a problem with there X51 and a CF GPS card? Im running tomtom v6.0 on this brand new PDA. I use a CF GPS reciever but im having some problems.
When navigating in TOMTOM, the graphics freezes, asif its stopped navigating, if i then go into the menu during navigation then exit out again, it will start navigating as normal, but then half a mile down the road it will just stop again (it will still have the signal). Its not the GPS reciever, and its not the TOMTOM v6.0 software as i have tested it with the same set-up settings, same gps reciever on my old PDA (Acer N10) which is years old compared to the X51.
I read a few things on the web about resolving the issue, some suggested a few fixes in activesync, this didnt work, a few suggested updated the X51's ROM version, which i did (to Version A04, does anyone know if there is a newer one out?)
Apart from that im clueless, i bet if i hook up a bluetooth GPS reciever it will work fine and dandy, is it just the X51's do not like CF for some reason or other?
upgrade to the offical Dell A12 Firmware or use custom football edition firmware (use google for the latter)
