Dell blow up
23 Jul 2005
Just turned my pc on and my Dell 2405fpw just blow up, I was running Eyeinfinity with 3 screens 2, Samsung Syncmaster p2450 and the Dell. My question is I need a replacement, what do I get as the p2450 are hard to find now, needs to be 24" and around £150 mark.
Thanks
does it need to have displayport for the eyefinity or will the syncmasters be able to sort that?
Edit: or will you be using an adapter of some kind?
Hi there,
Assuming you are looking for another 1920x1080 monitor to keep the eyefinity then this Iiyama is a good option within the budget. It won't offer the same image quality as the VA panel Dell, but it should look good enough and offer better motion handling and lower input lag.
Sorry, when I said "another" I meant 1920x1080 like the Samsung P2450s you currently have. As you mention that you are running them in eyefinity (ie. not configured independently) then you will want all the resolutions to be the same.
