Hi All I have just got a Dell XPS L702x Laptop and noticed there is a program installed called Dell Data Safe ,do i need to keep this or is it okay to uninstall it ? any ideas
It allows you to do a system backup to a memory stick (8GB+) or blank DVDs. This will create a means of system recovery so in the future you can restore back to how it was when you first got it.
You should do the system backup before removing the Dell Data Safe program.
