dell dimension case re-use?
10 Jan 2009
hi all, i have a dell dimension 9150 (p4 3ghz etc) that is a bit tierd and id like to know if i can change some bits over such as a spare asus p5k board in the same case? its a ok case to look at so i would rather re-use it than scrap it or whatever.
i guess i will need a new standard power supply?
can anyone offer any advice on doing this?
thanks :D
dont think its a xps mate? this one..
Even on the some of the ATX cases they have the io plate integrated into the chassis as I found out to my dismay so you can't change the mobo without hacking the case about with a dremel..
i found this out the hard way, for a while i had the on/off, reset button just sitting outside a different case, untill i took a whole dell case home from work. so annoying Dell are
