2 May 2006 at 17:47 #1 baldzone baldzone Associate Joined 7 Mar 2005 Posts 814 Would a Dell DVI cable be compatable with a HP monitor? Found some quite cheap and hoping it will be OK before I buy!
2 May 2006 at 18:05 #2 Baddass Baddass Man of Honour Joined 12 Jan 2003 Posts 20,629 Location UK pretty sure they are standard DVI cables, so should be ok. Check with the retailer?
2 May 2006 at 18:11 #3 baldzone baldzone Associate OP Joined 7 Mar 2005 Posts 814 tbh it's on fleabay but I'll ask the seller a question. Cheers!
2 May 2006 at 19:06 #4 Burbleflop Burbleflop Soldato Joined 7 May 2003 Posts 4,247 Location Away from here Baddass said: pretty sure they are standard DVI cables, so should be ok. Check with the retailer? Click to expand... Yep, spot on. I've got 50 or so Dell DVI cables kicking about at work and the few I've given away have all worked fine with other brands of monitor.
2 May 2006 at 19:11 #5 baldzone baldzone Associate OP Joined 7 Mar 2005 Posts 814 Have a look in the wanted section Burbleflop. There may be a post that interests you that I wrote. lol
