After you remove the stand you should be left with a square hole in the back of the monitor. Inside that hole will be four screws on 100m centres for the VESA mount.
Cheers!
Btw, I have a 1cm thick desk, currently it supports my 5kg monitor, but do you think it will support it once raised on a 5kg vesa arm 60cm higher?
