Dell Inspiron 1545 battery
Permabanned
25 Nov 2009
Rotherham Need: GHz
Hi folks,
I'm looking for a replacement battery for a DELL 1545. Can anyone tell me of a particular make/manufacturer that is more bang for buck rather than best?
Regards
Scotty
Any where off the bay
cheap as chips,pick a seller with a good rep
My experience is that they are cheap for a reason,usually last 12 months-18 months good capacity then go down hill,whereas a genuine one will last years but cost 4-5 times as much
I use the cheapy ones then bin after a year or so :D
