- 4 Aug 2009
Hey all,
This is my first post on a forum so as you can imagine i have tried searching google for this before posting here. As i've had no luck finding any "Concrete" info i thought that'd you'd be the best people for the job! lol
Basically i currently have a Dell Inspiron 6400 & i'm looking to upgrade the cpu from a "Intel Dual Core T2080" to whatever the best compatible "Intel Core 2 Duo" is. (So any suggestions on cpu's would be awesome!)
The only problem is i am a little (as in really really!) confused as to how i find out what cpu's are compatible! I was hoping that you may be able to shed some lite on the situation! lol
Apparently (according to less that concrete info on google! lol) i need to match the socket type, The max FSB Speed & the max CPU speed. so assuming that whatever cpu i choose meets those specs it should work?
I have used Sisoftware Sandra & CPUZ in an attempt to identify this info but i can only find my Socket type (Socket 479 mPGA/Socket P) & my "Chipset" FSB max speed. (800 Mhz) I can't seem to find my max cpu speed.
Any help on this subject would be awesome! It's seems to be a bit of a nightmare if you don't know what your doing! & obviously for the price of the cpu & the work to install, I don't wanna risk that it may not work! lol
Also, If anyone has any opinions on wether or not it's a worth while upgrade, that would be welcome. I do a lot of Audio Production using Cubase so i'm hoping that a new cpu will be worth the money to help cope with the cpu load of some of the projects.
My relevant Spec is as follows:
Dell Inspiron 6400
Motherboard Model: 0XD720
Chipset: Dell 955XM/945GM/PM/GMS/940GML
Max Chipset FSB Speed: 4x 200MHz (800 MHz)
CPU: Intel Dual Core T2080 1 M Cache, 1.73 GHz, 533 MHz FSB.
Socket type: Socket 479 mPGA/Socket P.
Hopefully thats everything! lol
If you need anymore info let me know.
Thanks for the help.
Sorry for the length of the post! lol
Dell Inspiron 6400
