Dell LED error codes.
19 Jan 2003
Bristol, UK
Trying to decipher what 10 flashes of the battery LED mean on an Inspiron 5160 laptop.
Have trawled Dell and Google with no luck. Any idea how I can find out?
TIA!
Ok then, I'll stop sulking as no one seems to like answering my threads :(
This answer isn't conclusive you understand, but my DELL has a constantly flashing battery LED. It flashes 4 times orange, then one time green, meaning that the battery is failing. I have a spare battery which doesn't cause it to flash, so I know the cirsuit in the laptop is not at fault. I have also googled it and found this to be the answer, in my case. Being the battery LED for you I would recommend trying another battery (if possible), but it may well be some other problem to do with power circuitry in your case.
Hope this helps you a little bit.
