I have a Dell OptiPlex GX270 (Small Desktop Computer), with a WD 500GB AAKS HDD installed, and am using it as a music file server to a SqueezeBox 3, have it setup with WOL enabled in BIOS, and XP pro set to go into Standby after 5 mins of inactivity, and then with the ability to wake it up with the remote of the SqueezeBox, using "Magic packets" for that purpose, by having WOL 1.0.3 installed, and ethernet adapter set up accordingly.
This setup has worked well for the last few months, but just last night when I went to wake it up, it refused to, and the led in the middle of the On/Off button started flashing amber, I had to power it off, by holding button in, and power on again to get it on again, but once on, it worked fine. The manual gives the following for this error:
If the power light is blinking amber — A device might be malfunctioning or incorrectly installed.
I then added a new PCI ethernet card, a Zyxel Dimension GN680T, which on setting up WOL to work (from Hibernation this time), was OK for a few days, then the original problem started again, but this time, it would not go into Standby, but the Power light flashes amber and the HDD light flashes green, and I have to hold the Power button in for 30-60 secs, before it fully powers off, then when switching it on it appears to run ok again.
What could be possibly causing this problem (might it be a faulty PSU), and how might I fix it?
Thanks.
- Remove and then reinstall the memory modules.
- Remove and then reinstall any cards.
- Remove and then reinstall the video card, if applicable.
- Toggle the voltage selection switch on the back of the computer.
- If the problem persists, contact Dell.
Thanks.
