Hey, I recently purchased a Dell Poweredge 900 case hoping to put my old packard bell board inside it (old case was messed up)...
However, I came across the problem of dell only making cases for there own motherboards
. It turns out these model of cases used a special type of board which does not require any tools.
Infact the motherboard (dell) which is supposed to fit this case uses some sort of special connecter to attack there motherboards (I think there some sort of plastic adaptors).
Anywho, my only option seems to cut off the connecters (where the screws go) within the old ATX case and use some sort of metal glue.
I was wondering which tools you suggest I used to do this, and if there is... Suggest another way?
I have seen a lot of custom cases produced from scratch so I was wondering if there was some sort of common screws, bolts etc which could be used.
Thanks a lot for reading!
. It turns out these model of cases used a special type of board which does not require any tools. Infact the motherboard (dell) which is supposed to fit this case uses some sort of special connecter to attack there motherboards (I think there some sort of plastic adaptors).
) you'll get the Dubs, normally the cheapo home system Dimensions mean you get india. Either way, Dell's support is easy to work with:
