Hi All
I have a server at home that i play around with that has only got 4gb of memory, I am having problems finding some extra memory to upgrade. I was told that some ram i have just got on fleebay would work just fine so ordered it from the states to find i am still having a problem with it saying memory configured bad
I have ordered this memory - Type: pc3-8500r. DDR3 ECC REGISTER DIMM
SPEED: 1066mhz
Form Factor: 240pin
Capacity: 16GB. you will receive 4 stick of 4gb.
The listing states it will work so am i doing anything wrong. Do i need to configure this at all?
Thanks
Dave
SPEED: 1066mhz
Form Factor: 240pin
Thanks
Dave
